1 Reply Latest reply on Dec 10, 2013 1:57 PM by Tim Coble
    CSWP sample exam- Equation Problem
    Maria Rosaria Palminteri
      Hello everyone!
      I am trying to prepare for CSWP CORE exam and I was trying to work on the sample that is available from SW.
      All is fine expect I am encountering a problem with the equation. I have created a bunch of global variables, but when I try to update each of them for answering a new question it simply takes a lot of time.
      I am not re-building automatically, but as soon as I enter a value inside a global variable, it takes a lot to update.
      I am concerned about this since I think it may make minutes run out during the real exam. Has anyone suggestions for improving this?
      Here there are the equations I am using.
      "A"=213
      "D1@Sketch2"="A"
      "B"=200
      "D2@Sketch2"="B"
      "C"= 170
      "D1@Sketch4"="C"
      "D2@Sketch4"="C"
      "X@Sketch7"="A"/3
      "D"=130
      "D2@Boss-Extrude4"  = "D" - 10
      "E"=41
      "D1@Sketch8"="E"
      "D1@Cut-Extrude2"  = "D"
      "D1@Sketch9"="B"/3 +10mm
      "D2@Boss-Extrude5" = "D" - 10
      "D1@Sketch10"="E"
      "D1@Cut-Extrude3"  = "D"
        • Re: CSWP sample exam- Equation Problem
          Tim Coble
          Maria,
          With the exception of how you set up the offset of the bores ("D2@Boss-Extrude4"  = "D" - 10 - I used offset in the extrude feature), everything looks OK.
          The one thing I did differently was to make some of the dimensions equal to each other.  For example: "D1@Sketch10" = "D1@Sketch8"  instead of having both equal to "E".  The same thing can be done for D and C.  It may help your processing time.
          I completed the first segment of the core exam this past Saturday and I had no problem with time.  You'll probably be fine.
          Good luck!
