5 Replies Latest reply on Aug 27, 2015 2:54 PM by Dave Branco
    Is there a way to get temp axis of cylindrical face?
    Tore Magne Bjornodegard
      As the title states, is there a way to get temp axis of cylindrical face? I cant find enything about temp axis in API help, and it seems that the axis does not have any names...
      This is in assembly.
      Thanks!
        • Re: Is there a way to get temp axis of cylindrical face?
          Terrell Sprecher
          My assembly in the centre has a cylinder, however it is broke with a seam so the axis obviously doesn't show. But all the othe axis' show such as the blue one in the background for the sheet as a whole. These are simply reference geometry and can be shut off and on with the push of the View Temporary Axis button.
            Artem Taturevych
            I'm afraid the only way to access the temporary axis is select it by coordinate:
            swModel.Extension.SelectByID2 "", "AXIS", -1, 0, 0, False, 0, Nothing, 0
            ____________________________________________________
            Regards,
            Artem Taturevych, Application Engineer at Intercad (Australia)
            translationXpert – add-in to translate SolidWorks models
            myIntercad an integrated tool for SolidWorks Professionals
            LinkedIn SolidWorks API Education Group
                Thanks for answers!
                What i wanted to do is to make a macro that could convert the face selection to temp axis selection, it is time consuming to select the right axis when you have a lot of them on top of each other....
                I see that this will hard to do if even possible...
                    Dave Branco
                    Hey not sure if you are still looking for an answer to this question but I was and i have a solution for you.  It's true that you need to select the axis by the coordinate (i believe) but that is easy enough to find.  This macro will select the temporary axis of the selected face.  note that temporary axes need to be visible in order to select them.  I dont like all the clutter, so that macro shows them and hides them after it is already selected:
                    ' Preconditions: Model document is open and a cylindrical surface is selected.
                    ' Postconditions: The temporary axis of that surface is selected
                    Option Explicit
                        Dim swApp                   As SldWorks.SldWorks
                        Dim swModel                 As SldWorks.ModelDoc2
                        Dim swSelMgr                As SldWorks.SelectionMgr
                        Dim swFace                  As SldWorks.Face2
                        Dim swSurf                  As SldWorks.Surface
                        Dim vCylinder               As Variant
                        Dim i                       As Long
                        Dim bRet                    As Boolean
                        'Set swApp = CreateObject("SldWorks.Application")
                        Set swModel = swApp.ActiveDoc
                        Set swFace = swSelMgr.GetSelectedObject5(1)
                        Set swSurf = swFace.GetSurface
                        If swSurf.IsCylinder Then
                            vCylinder = swSurf.CylinderParams
                            Debug.Print "origin         = (" & vCylinder(0) * 1000# & ", " & vCylinder(1) * 1000# & ", " & vCylinder(2) * 1000# & ") mm"
                            Debug.Print "axis           = (" & vCylinder(3) & ", " & vCylinder(4) & ", " & vCylinder(5) & ")"
                            Debug.Print "radius         = " & vCylinder(6) * 1000# & " mm"
                            bRet = swModel.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, True)
                            bRet = swModel.Extension.SelectByID2("", "AXIS", vCylinder(0), vCylinder(1), vCylinder(2), False, 0, Nothing, 0)
                            bRet = swModel.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, False)
                      Dave Branco
                      I took it one step further in case you would like to select the axis within an assembly:
                      Sub test()
                          Dim swselmgr                As SldWorks.SelectionMgr
                          Dim i                       As Long
                          Dim bret                    As Boolean
                          Set swselmgr = swModel.SelectionManager
                          Set swFace = swselmgr.GetSelectedObject5(1)
                          Dim swXform As MathTransform
                          Dim swmathutil As MathUtility
                          Dim swcomp  As Component2
                          If swModel.GetType = swDocASSEMBLY Then
                              'need a transform
                              Set swmathutil = swApp.GetMathUtility
                              Set swcomp = swselmgr.GetSelectedObjectsComponent(1)
                              Set swXform = swcomp.Transform2
                          Dim myaxis() As Double
                          ReDim myaxis(1 To 3)
                              myaxis(1) = vCylinder(0)
                              myaxis(2) = vCylinder(1)
                              myaxis(3) = vCylinder(2)
                                  'transform the axis origin to assembly space
                                  Dim mypoint As MathPoint
                                  Set mypoint = swmathutil.CreatePoint(myaxis)
                                  Set mypoint = mypoint.MultiplyTransform(swXform)
                                  myaxis(1) = mypoint.ArrayData(0)
                                  myaxis(2) = mypoint.ArrayData(1)
                                  myaxis(3) = mypoint.ArrayData(2)
                                'display temp axes so you can select them
                              bret = swModel.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, True)
                             bret = swModel.Extension.SelectByID2("", "AXIS", myaxis(1), myaxis(2), myaxis(3), False, 0, Nothing, 0)
                             Debug.Assert bret
                              'hide the temporary axes
                             bret = swModel.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, False)
