I have an assembly with multiple parts that are the same. For example, I am using the same pulley multiple times. Whenever I try to suppress just 1 of the pulleys, SW instead suppress ALL the pulleys in the assembly. What is going on? This is frustrating.
This only started happening when I started using SW2014.
All the pulleys are the same sldprt file?
Are you sure you were not Hiding the part before?
When you Suppress it dumps the file out of memory and will supress all the instances loaded in SolidWorks.
Try Hiding your part.
Cheers,
Anna
