0 Replies Latest reply on Dec 3, 2013 10:42 AM by Tyler Banschbach
    Change sheet format for specific sheet per file -> Help
    Tyler Banschbach
      Hi everyone,
      I'm going to attach some code that may be beneficial. What I want to do is change the format of every sheet that has the word "Packaging" in the sheet name from one sheet format to another in x amount of files per specific folder. In essence I have a folder for all of these drawings and I would like to change all of the packaging specs of each drawing in that folder from 8-1/2"x11" to 11"x17" and have everything scale appropriately. I doubt it will work that well so instead I've made a seperate sheet format that I would like to replace all of those sheets with "Packaging" in their sheet name. I know this is possible but my experience with VBA is very very limited. Heres what I have thus far:
      Option Explicit
      Dim swModel As ModelDoc2
      Dim swFilename As String
      Dim swSheet As SldWorks.Sheet
      Dim bRet As Boolean
      Dim Path As String
      Dim nErrors As Long
      Dim nWarnings As Long
      Dim DocName As String
      Dim i As Long
      Dim vSheetName As Variant
      Public Const sTemplatePath As String = "A:\Engineering_Files\SW Backup Files\Settings"
          Path = "A:\Engineering_Files\Current Product 2011\Drawings\1 Sq Picket"
          swFilename = Dir(Path & "*.SLDDRW")
          Do Until swFilename = ""
          Set swModel = swApp.OpenDoc6(Path + swFilename, swDocDRAWING, swOpenDocOptions_Silent, "", nErrors, nWarnings)
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          vSheetName = swDraw.GetSheetNames
          For i = 0 To UBound(vSheetName)
             bRet = swDraw.ActivateSheet(vSheetName(i))
      'Put the required sheet format name
             swDraw.SetupSheet4 vSheetName(i), swDwgPaperCsize, 12, 1, 1, False, sTemplatePath & "westech packaging-11x17.slddrt", 0#, 0#, "Default"
              swModel.ViewZoomtofit2
          Next i
      ' Switch back to first sheet and change format
          bRet = swDraw.ActivateSheet(vSheetName(0))
          swDraw.SetupSheet4 vSheetName(0), swDwgPaperCsize, 12, 1, 1, False, sTemplatePath & "westech packaging-11x17.slddrt", 0#, 0#, "Default"
          swModel.ForceRebuild3 (False)
          swModel.Save
      'swApp.CloseDoc swModel.GetTitle
         Set swModel = Nothing
         swFilename = Dir
      Loop
      MsgBox "Make sure it worked!"
