We just upgraded to SW 2014 and today to SP1. When stepping in PCB files from Altium they no longer show up populated with parts. They imported fine in 2013 and into our seat of Catia, do not load correctly in 2014. Is there a fix on the way for this? The attached image shows the step results from 2014 on the left and from 2013 on the right using the same file. Please help.
Brandon
Turns out it had to do with templates. You have to open and save all the part, assembly and drawing templates to 2014. Once you do that STEP files will open fine.
- Brandon
