4 Replies Latest reply on Dec 6, 2013 12:30 AM by Sanjay Phadke
    convert entities property page manager
    Sanjay Phadke
      I am writing a macro where user select the hidden line in drawing view
      then user selects hidden line immediately after this I want to call convert entities property page manager
      so that line will be created on view
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      Set swModel = swApp.ActiveDoc
      Set Part = swModel
      Set swModelDocExt = swModel.Extension
      Set swModelView = swModel.GetFirstModelView
      Set TheMouse = swModelView.GetMouse
      obj.init TheMouse
      Part.ClearSelection2 True
      swApp.SendMsgToUser "PLEASE SELECT THE VIEW"
      boolstatus = Part.ActivateView("")
      boolstatus = Part.Extension.SelectByID2("", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
      Part.ViewDisplayHiddengreyed
      swApp.SendMsgToUser "SELECT THE LINE\LINES 2 CONVERT"
      '''''''here I want to call property page manager dialog''''''''''''''
      end sub
        • Re: convert entities property page manager
          Matt Martens
          If you use swapp.runcommand to access convert entities prior to making your selections the convert entities property manager will pop up (if you call convert entities after making a selection, it simply converts the entities without opening the PMP).
          swApp.RunCommand swCommands_ConvertEntities, ""
          end sub
          However, the macro will continue on without waiting for the command to finish. I tried to find out how to force the macro to wait for the completion of the command before resuming but was unsuccessful. Hopefully, someone else can come in and help with that part.
            Matt Martens
            I figured it out!
            Dim swmodel As SldWorks.ModelDoc2
            Dim boolstatus As Boolean
            Set swmodel = swApp.ActiveDoc
            Do
              swApp.GetRunningCommandInfo 0, 0, boolstatus
              DoEvents
            Loop While boolstatus = True
            The do while loop will run and allow the user to select any lines, but as soon as the property manager's check or cancel buttons are pressed the loop ends and moves on.
                Sanjay Phadke
                instead of this swApp.RunCommand swCommands_ConvertEntities, ""
                use following
                Set swSketchManager = swModel.SketchManager
                        boolstatus = swSketchManager.SketchUseEdge2(False)
                it works well
                But I want now after converting the entities view selection should be remained but it is not happening
                after end function view selection does not remain, pls guide me
                sub function test()
                Set VW = Part.ActiveDrawingView
                VW.SetDisplayMode 2
                end function
