8 Replies Latest reply on Jun 18, 2016 6:40 AM by Yong Ning
    How to select bomtable in Feature.
    Yong Ning
      Select bomtable code  result is
      ITEM NO.
      PART NUMBER
      QTY.
          Dim swApp                   As SldWorks.SldWorks
          Dim SwModel                 As SldWorks.ModelDoc2
          Dim swSelMgr                As SldWorks.SelectionMgr
          Dim swTable                 As SldWorks.TableAnnotation
          Dim swBomTable              As SldWorks.BomTableAnnotation
          Dim i                       As Long
          Set SwModel = swApp.ActiveDoc
          Set swSelMgr = SwModel.SelectionManager
          Set swTable = swSelMgr.GetSelectedObject5(1)
          For i = 0 To swTable.ColumnCount
              Debug.Print swTable.GetColumnTitle(i)
          Next i
      Help. know bomtable name. How to select bomtable?
      for example. Know  bomtable name of Bill of Materials1
      'boolstatus = SwModel.Extension.SelectByID2("Bill of Materials1", "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0)
          Set swTable = ????????????
          • Re: How to select bom in Feature.
            Yong Ning
            Thank your code
            Dim sBOMname As String
            Dim swView As SldWorks.View
            Dim swSheetView As SldWorks.View
            Dim swDrawing As SldWorks.DrawingDoc
            Dim swBomFeat   As SldWorks.BomFeature
            Dim swFeat As SldWorks.Feature
            Dim swBOM As SldWorks.Feature
            Sub Main()
                Set swModel = swApp.ActiveDoc
                Dim swSelMgr As SelectionMgr
                Dim swTable As TableAnnotation
                Set swDrawing = swModel
                Set swSelMgr = swDrawing.SelectionManager
                Set swFeat = swDrawing.FirstFeature
                'Get BOM name
                Do While Not swFeat Is Nothing
                    If "BomFeat" = swFeat.GetTypeName Then
                        Set swBomFeat = swFeat.GetSpecificFeature2
                        Set swBOM = swBomFeat.GetFeature
                        sBOMname = swBOM.Name
                        swModel.Extension.SelectByID2 sBOMname, "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0
                        Debug.Print sBOMname
                        Stop
                        Set swTable = swSelMgr.GetSelectedObject5(1)    → error is Type mismatch (error 13)
                        Exit Do
                    Set swFeat = swFeat.GetNextFeature
                Loop
            Help me
            the code error is Type mismatch (error 13)
                Simon Turner
                will return a BomFeature object.
                So, declare a BomFeature variable:
                Dim myBom as BomFeature
                Set myBom = swSelMgr.GetSelectedObject5(1)
                Then use myBom.GetTableAnnotations
                • Re: How to select bomtable in Feature.
                  Yong Ning
                  Sub del20160617()
                      Dim Xls As Excel.Application, Rng As Range
                          Set Xls = GetObject(, "Excel.Application")
                      Dim Sht As Worksheet
                          Set Sht = Xls.Worksheets("Drawing")
                      Dim BomRng As Range, WidthFactorRng As Range, BomXyRng As Range
                      Dim ColWidthRng As Range, RowHightRng As Range, tRng As Range
                           With Sht
                                Set BomRng = .Range(.Cells(5, 2).Formula)
                                Set WidthFactorRng = .Range(.Cells(5, 3).Formula)
                                Set BomXyRng = .Range(.Cells(5, 4).Formula)
                                Set ColWidthRng = .Range(.Cells(5, 5).Formula)
                                Set RowHightRng = .Range(.Cells(5, 6).Formula)
                                ''Debug.Print BomRng.Address, WidthFactorRng.Address, BomXyRng.Address, ColWidthRng.Address, RowHightRng.Address
                           End With
                      Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                           Set SwApp = Application.SldWorks
                           Set SwModel = SwApp.ActiveDoc
                      Dim SwSelMgr As SelectionMgr
                           Set SwSelMgr = SwModel.SelectionManager
                      Dim SwTabAnn As TableAnnotation, SwTextFormat As TextFormat, SwAnn As Annotation
                           Set SwTabAnn = SwSelMgr.GetSelectedObject5(1)
                           With SwTabAnn
                               For ii = 0 To .RowCount - 1
                                  For jj = 0 To .ColumnCount - 1
                                      Set SwTextFormat = .GetCellTextFormat(ii, jj)
                                      If ii = .RowCount - 1 Then
                                             .Text(ii, jj) = BomRng(1, jj + 1)
                                             Set SwTextFormat = WidthFactorTextFormat(SwTextFormat, BomRng(1, jj + 1), WidthFactorRng(1, jj + 1), 0.05)
                                             .SetColumnWidth jj, ColWidthRng(1, jj + 1) / 1000, 0
                                             .SetRowHeight ii, RowHightRng(1, 1) / 1000, 0
                                      Else
                                             .SetRowHeight ii, RowHightRng(2, 1) / 1000, 0
                                             Set SwTextFormat = WidthFactorTextFormat(SwTextFormat, BomRng(2, jj + 1), WidthFactorRng(2, jj + 1), 0.05)
                                      .SetCellTextFormat ii, jj, False, SwTextFormat
                                  Next jj
                               Next ii
                               Set SwAnn = .GetAnnotation
                               .AnchorType = BomXyRng(1, 3)
                           End With
                           With SwAnn
                                .SetPosition BomXyRng(1, 1) / 1000, BomXyRng(1, 2) / 1000, 0
                                .Layer = "文本"
                           End With
                  Function WidthFactorTextFormat(TextFormat As TextFormat, Rng As Range, wFactor, LineSpec) As TextFormat
                    With TextFormat
                           '.Italic = Rng.Font.Italic
                           .Bold = Rng.Font.Bold
                           .LineSpacing = LineSpec / 1000
                           .CharHeight = (Rng.Font.Size - 6) / 1000
                           .TypeFaceName = Rng.Font.Name
                           .WidthFactor = wFactor
                    End With
                    Set WidthFactorTextFormat = TextFormat
                  End Function
                      Yong Ning
                      Function MainPlateBOM(SwBomTabAnn As BomTableAnnotation, SwTabAnn As TableAnnotation, cArr, Arr, wArr, Xx, Yy, oAnchorType)
                             Xx = Xx / 1000
                             Yy = Yy / 1000
                             With SwTabAnn
                                For jj = 0 To UBound(cArr)  ' .ColumnCount - 1
                                   .SetColumnWidth jj, wArr(jj) / 1000, 0
                                   .SetColumnTitle jj, cArr(jj)
                                   SwBomTabAnn.SetColumnCustomProperty jj, Arr(jj)
                                Next jj
                                   If ii = .RowCount Then
                                      .SetRowHeight ii, 0.01, 0
                                   Else
                                      .SetRowHeight ii, 0.005, 0
                                Next ii
                                .AnchorType = oAnchorType
                                SwAnn.SetPosition Xx, Yy, 0
                             End With
                      End Function
                      Private Sub ChangeBOM()
                          Dim Arr(1), cArr(1), wArr(1)
                            cArr(0) = Array("序号", "标 准 号", "名        称", "数量", "材  料", "质量" & Chr(13) & "(单)", "质量" & Chr(13) & "(合)", "备  注")
                            Arr(0) = Array("", "标准号", "名称", "", "材料", "质量", "", "备注")
                            wArr(0) = Array(10, 25, 50, 12, 25, 15, 18, 25)
                            cArr(1) = Array("件号", "名    称", "模型质量", "下料尺寸", "下料质量", "数量", "材料", "δ", "下料质量-模型质量", "备  注")
                            Arr(1) = Array("件号", "名称", "质量", "下料尺寸", "下料质量", "", "材料", "δ", "", "")
                            wArr(1) = Array(10, 40, 15, 35, 15, 10, 20, 8, 40, 15)
                          Dim SwFeat As Feature, SwBomFeat As BomFeature
                          Dim SwBomTabAnn As BomTableAnnotation, SwTabAnn As TableAnnotation
                              Set SwFeat = SwModel.FirstFeature
                              Do While Not SwFeat Is Nothing
                                 If UCase(SwFeat.Name) Like "*BOM*" And SwFeat.GetTypeName = "BomFeat" Then
                                    SwFeat.Select True
                                    Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
                                    Set SwBomTabAnn = SwBomFeat.GetTableAnnotations(0)
                                    Set SwTabAnn = SwBomTabAnn
                                    'Debug.Print SwFeat.Name, SwFeat.GetTypeName
                                    If UCase(SwFeat.Name) Like "*MAIN*" Then
                                       MainPlateBOM SwBomTabAnn, SwTabAnn, cArr(0), Arr(0), wArr(0), 420 - 5, 30, swBOMConfigurationAnchor_BottomRight
                                    ElseIf UCase(SwFeat.Name) Like "*PLATE*" Then
                                       MainPlateBOM SwBomTabAnn, SwTabAnn, cArr(1), Arr(1), wArr(1), 25, 5, swBOMConfigurationAnchor_BottomLeft
                                          With SwTabAnn '
                                             For ii = .RowCount To 0 Step -1
                                               If .Text(ii, 3) Like "*板材*" Then
                                                  Debug.Print .Text(ii, 6)
                                               Else
                                                 .DeleteRow (ii)
                                             Next ii
                                          End With
                                 Set SwFeat = SwFeat.GetNextFeature
                                 SwModel.ClearSelection2 True
                              Loop
                      Set SwBomFeat = SwFeat.GetSpecificFeature2  ' SwSelMgr.GetSelectedObject5(1)
                          Yong Ning
                          Private Sub ll1()
                             Dim Visible
                             Dim SwBomFeat As BomFeature, SwBomTabAnn As BomTableAnnotation
                                Set SwBomTabAnn = SwSelMgr.GetSelectedObject5(1)
                                With SwBomTabAnn
                                    Ss = .GetComponents(1)
                                End With
                            Dim SwComp As Component2
                                With SwTabAnn
                                   For ii = 1 To .RowCount - 1
                                      Ss = SwTabAnn.GetComponents(ii)
                                      Set SwComp = Ss(0)
                                      Debug.Print SwComp.Name2, SwComp.GetModelDoc.GetTitle,
                                      Debug.Print SwComp.ReferencedConfiguration
                                   Next ii
                                End With
                                Stop
                          End S
                          Private Sub ll()
                             Dim SwDraw As DrawingDoc
                                 Set SwDraw = SwModel
                             Dim vSheet, SwSheet As Sheet, SwView As View
                                 vSheet = SwDraw.GetSheetNames
                             Dim sConfig
                                 For ii = 0 To UBound(vSheet)
                                    SwDraw.ActivateSheet (vSheet(ii))
                                    Set SwSheet = SwDraw.GetCurrentSheet
                                    Set SwView = SwDraw.GetFirstView
                                    Set SwView = SwView.GetNextView
                                    sConfig = SwView.ReferencedConfiguration
                                    tmp = SwModel.Extension.SelectByID2(vSheet(ii) & "BOM", "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0)
                                    If tmp Then
                                        BOMConfiguration SwBomFeat, sConfig
                                 Next ii
                          Function BOMConfiguration(SwBomFeat As BomFeature, sConfig)
                              Dim Names, Visibles
                                        With SwBomFeat
                                           Names = .GetConfigurations(False, Visibles)
                                           For jj = 0 To UBound(Names)
                                               Visibles(jj) = False
                                               If sConfig = Names(jj) Then
                                                   Visibles(jj) = True
                                           Next jj
                                           .SetConfigurations False, Visibles, Names
                                        End With
                          End Function
