1 Reply Latest reply on Nov 26, 2013 3:06 PM by Anna Wood
    2014 Install Error Message
    Rick Becker
      I’m installing 2014 that I downloaded. I’m getting the following message… (see attached)
      Any idea why Outlook and SolidWorks are using the same files? I'm fearfull of changing something in my Outlook and having the program not work. It just seems odd that the 2 programs share anything.
      I am trying to contact my VAR but have been onhold for over an hour now and would like to finish up the install.
      Thank you in advance for helping
        • Re: 2014 Install Error Message
          Anna Wood
          Do not worry about that... Ignore and continue with your install.
          What the message is telling you is that you may need to restart your computer after the install is done.  There is a process running that SolidWorks needs to update.  It will update after you restart your system.  Not any different then when Windows or other software needs to do a system restart after install.
          Cheers,
          Anna
