I'm making a seat for a chair, which has ribs on the bottom. The seat is double curved. If I use the draft tool for the ribs, the thickness of the ribs is uneven since the pull direction is a non-curved plane. Is there a way to draft all the ribs with an even thickness? The ribs are and extruded boss base.
See the picture below.
Thanks!
Loeke
Use parting line draft instead of neutral plane draft, and you'll need a parting line along the base or top of your ribs. You'll probable need to build a curve to reference as your parting line.
