I want to take a value in my assembly configuration manager and with this value I want to multiply quantity of each part of my assembly.
I had Assembly.CustomInfo2("", "Qteass") in the code.
Why It dosent work?
Thanks for help me !
Dim swApp As Object
''Originally an equation built by Josh Brady of the Solidworks Forums
''WILL AUTO SUM THE QUANTITY OF UNIQUE PARTS IN ALL ASSEMBLIES WHEN RAN FROM THE TOP ASSEMBLY.
''CURRENTLY NEED TO MANUALLY ADD CUSTOM PROPERY 'Cfg4Qty'-'Text'-'Default' TO TOP LEVEL ASSEMBLY BEFORE RUNNING
Sub UpdateQtys()
Dim swApp As SldWorks.SldWorks 'added this line
Dim Assembly As ModelDoc2 'added this line
Dim myAsy As AssemblyDoc
Dim myCmps
Dim Cfg As String
Dim CmpDoc As ModelDoc2
Dim i As Long
Dim j As Long
Dim cCnt As Long
Dim NoUp As Long
Dim myCmp As Component2
Dim tCmp As Component2
Dim tm As Double
tm = Timer
Set swApp = Application.SldWorks 'added this line
Set Assembly = swApp.ActiveDoc 'added this line
Set myAsy = Assembly
If Assembly.ConfigurationManager.ActiveConfiguration.Name <> Assembly.CustomInfo2("", "Cfg4Qty") Then
Assembly.Extension.ShowSmartMessage "Qtys not updated due to config", 1000, True, True
Exit Sub
NoUp = 0
myCmps = myAsy.GetComponents(False)
For i = 0 To UBound(myCmps)
Set myCmp = myCmps(i)
If (myCmp.GetSuppression = 3) Or (myCmp.GetSuppression = 2) Then
cCnt = 0
Set CmpDoc = myCmp.GetModelDoc
Cfg = myCmp.ReferencedConfiguration
For j = 0 To UBound(myCmps)
Set tCmp = myCmps(j)
If tCmp.GetSuppression <> 0 Then
If tCmp.GetModelDoc2 Is CmpDoc Then
If tCmp.ReferencedConfiguration = Cfg Then
cCnt = cCnt + 1
Next j
CmpDoc.AddCustomInfo3 Cfg, "AutoQty", 30, ""
CmpDoc.AddCustomInfo3 Cfg, "QtyIn", 30, ""
CmpDoc.CustomInfo2(Cfg, "AutoQty") = cCnt * Assembly.CustomInfo2("", "Qteass")
CmpDoc.CustomInfo2(Cfg, "QtyIn") = Assembly.GetTitle & " Cfg " & Assembly.ConfigurationManager.ActiveConfiguration.Name
Else
NoUp = NoUp + 1
Next i
Assembly.Extension.ShowSmartMessage NoUp & " Parts not updated due to lightweight (" & Timer - tm & "s)", 10000, True, True
