RSReuben Symons24/11/2013
Hi
I've drawn a sketch on a plane and fully dimensioned it, including some vertical/horizontal relations. When trying to loft I reallised my plane was in slightly the wrong place so edited this to update the plane position. However in doing this the plane was rotated 90degrees such that my sketch now appears on it's side. Is there a way to rotate the plane 90degrees to correct this, it is only defined with a normal to line and coincident to point so from my perspective rotation should not be fixed.
(Using Solidworks 2013)
