8 Replies Latest reply on Nov 25, 2013 6:01 AM by Nazar Chaykin
    Not working swDoc.Save()
    Nazar Chaykin
      Hello! I get custom property and try to set new custom property, but when I try save the document nothing happened.
      Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
           swCfg.SetCustomProperty("Name", TextBox4.Text)
           swDoc
      .Save()
           swDoc.Close()
      But if use SwDoc.SaveAs(C:\1.sldasm) it work greatly.
        • Re: Not working swDoc.Save()
          Simon Turner
          Use Save3 and see what errors or warnings are returned:
          Dim errors as Long
          Dim warnings as Long
          swDoc.Save3 swSaveAsOptions_Silent, errors, warnings
          debug.print errors
          debug.print warnings
              Nazar Chaykin
              Sorry, I forgot to clarify that I used Document Management API
                  Simon Turner
                  In that case, did you ask for write access to the file when opening it? It will open it read-only by default.
                  Please specify the command you use to open the file.
                      Nazar Chaykin
                      Imports SolidWorks.Interop.swdocumentmgr
                      Public Class Form1
                      Dim swCfgMgr As SwDMConfigurationMgr
                      Dim vCfgNameArr As Object
                      Dim swCfg As SwDMConfiguration
                      Dim swDoc As SwDMDocument
                      Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
                           Dim swClassFact As SwDMClassFactory
                           Dim swDocMgr As SwDMApplication
                           Dim vCfgName As Object
                           Dim nDocType As Long
                           Dim nRetVal As Long
                              Dim sDocFileName As String = "C:\123.sldasm"
                              ' Determine type of SolidWorks file based on file extension
                              If InStr(LCase(sDocFileName), "sldprt") > 0 Then
                         nDocType = SwDmDocumentType.swDmDocumentPart
                              ElseIf InStr(LCase(sDocFileName), "sldasm") > 0 Then
                         nDocType = SwDmDocumentType.swDmDocumentAssembly
                              ElseIf InStr(LCase(sDocFileName), "slddrw") > 0 Then
                         nDocType = SwDmDocumentType.swDmDocumentDrawing
                              Else
                         ' Not a SolidWorks file
                         nDocType = SwDmDocumentType.swDmDocumentUnknown
                         ' So cannot open
                         Exit Sub
                              ' Because drawing documents do not have configurations,
                              ' only continue running the project if the document
                              ' is a part or assembly document
                              If (nDocType <> SwDmDocumentType.swDmDocumentDrawing) Then
                         swClassFact = CreateObject("SwDocumentMgr.SwDMClassFactory")
                         swDocMgr = swClassFact.GetApplication(sLicenseKey)
                         swDoc = swDocMgr.GetDocument(sDocFileName, nDocType, True, nRetVal) : Debug.Assert(SwDmDocumentOpenError.swDmDocumentOpenErrorNone = nRetVal)
                         swCfgMgr = swDoc.ConfigurationManager
                         TextBox1.Text = swDoc.Title 'наименование
                            vCfgNameArr = swCfgMgr.GetConfigurationNames
                         For Each vCfgName In vCfgNameArr
                             swCfg = swCfgMgr.GetConfigurationByName(vCfgName)
                             TextBox2.Text = swCfg.GetCustomProperty("Name", 30)  'Сборка1_ФБ
                         Next
                      swDoc.Save()
                      Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
                           swCfg.SetCustomProperty("Name", TextBox2.Text)
                           swDoc.Save()
                           swDoc.CloseDoc()
                      Close()
                      End Class
