Currently i'm designing a new printhead for a 3D printer. This is a engineeringsproject for school, i'm in the second year of mechanical engineering.
A big issue with FFF 3D printers is jamming of the filament inside the extruder. I designed a new extruder in SolidWorks and i want to simulate the behavior of the liquide thermplastic inside the extruder. I attached a very simple design so you can see where it's about. The 6.2mm hole is for a 40 Watt heatercardridge for heating the nozzle. When the nozzle is hot the plastic melts in the heatcamber and will be pushed outside true the 0.35mm hole.
Is it possible to simulate this within SolidWorks? I want to study the behavior of the liquide plastic so i can design a reliable new extruder.
Specifications:
Material nozzle Aluminium
Printing material ABS
Working Temp 30degree
Velocity filament 0.76mm/sec
Heatercardridge 40Watt
Nozzle diameter ø35mm
Filament diameter ø1.75mm
John
you want to see how the plastic comes out of the print head? not possible in solidworks flow simulation. you'll have to go to something like abaqus.
solidworks flow simulation would help you understand how it flows inside the print head. you'd probably need non newtonian material properties to get it to work right.
if you know how things will behave if you understand how the heat is distributed in the printer head, this is definitely possible. but you need to have that understanding first.
