When I use the section view tool in an assembly to cut a section and then change to a different configuration it seems that sometime the section stays and other time it go away when the configuration changes. Does anyone else notice this behavior?
I did a little experimenting and it seems that if you pick surface of a part in a sub-assembly to cut the section the section will go away when the configuration is changed. If you pick a surface of a part in the top level assembly the section view will persist when changing configurations. The work around is to create a work plane in the main assembly based on the surface of the part in a sub-assembly and then create the section view using the work plane. The section view will then persist.
