3 Replies Latest reply on Nov 22, 2013 10:25 AM by Todd Bennett
    How to export at Coordinate System1?
    Todd Bennett
      I have a simple export tool that Deepak Gupta wrote.  It saves a part file as an iges.  However, I want it to use a custom coordinate system.
      I always leave the coordinate system named the default (Coordinate System1).
      Any help is appreciated.
      Here's the relevant snip:
      sPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
      sModelName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
      sModelName = Left(sModelName, InStrRev(sModelName, ".") - 1)
      swModel.SaveAs (sPath & sModelName & ".igs")
        • Re: How to export at Coordinate System1?
          Artem Taturevych
          Try this:
          swModel.Extension.SetUserPreferenceString swUserPreferenceString_e.swFileSaveAsCoordinateSystem, swUserPreferenceOption_e.swDetailingNoOptionSpecified, "Coordinate System1"
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Todd Bennett
              You have a little typo: swUserPreferenceString_e.sw... should be swUserPreferenceStringValue_e.sw...
              Thank you, it worked great once I figured this out.
                Todd Bennett
                Here's the modified code (below).
                Option Explicit
                    Dim swApp                   As SldWorks.SldWorks
                    Dim swModel                 As SldWorks.ModelDoc2
                    Dim sPath                   As String
                    Dim sModelName              As String
                    Dim bRebuild                As Boolean
                Sub Main()
                    Set swModel = swApp.ActiveDoc
                    'Check a file is Open
                    If swModel Is Nothing Then
                    swApp.SendMsgToUser2 "Please open a PART file!", swMbWarning, swMbOk
                    Exit Sub
                   'Check that active file is a Part file
                    If swModel.GetType <> swDocPART Then
                    swApp.SendMsgToUser2 "Not a Part File, please open a PART file!", swMbWarning, swMbOk
                    Exit Sub
                    'Force Rebuild
                    bRebuild = swModel.ForceRebuild3(False)
                    'Get file path
                    'Get File Name Without extension
                    'Set Save path
                    sPath = sPath '& sModelName & "\"
                    'Use the custom coordinate system
                    swModel.Extension.SetUserPreferenceString _
                    swUserPreferenceStringValue_e.swFileSaveAsCoordinateSystem, _
                    'Save file as IGES
