2 Replies Latest reply on Nov 22, 2013 4:01 AM by Yong Ning
    How to change the property name in custinfo?
    Yong Ning
      Help
      Change property name b1 → change → a1
      Follow Code can be the property name. can be display property name.
          Dim swApp                           As SldWorks.SldWorks
          Dim swModel                         As SldWorks.ModelDoc2
          Dim vConfigNameArr                  As Variant
          Dim vConfigName                     As Variant
          Dim vCustInfoNameArr                As Variant
          Dim vCustInfoName                   As Variant
          Dim bRet                            As Boolean
          Set swModel = swApp.ActiveDoc
          Debug.Print "File = " & swModel.GetPathName
          vConfigNameArr = swModel.GetConfigurationNames
          ' Is empty if a drawing becasue configurations not supported on drawings
          If IsEmpty(vConfigNameArr) Then
              ReDim vConfigNameArr(0)
              vConfigNameArr(0) = ""
          Else
              ' Add a blank string for the nonconfiguration-specific custom properties
              ReDim Preserve vConfigNameArr(UBound(vConfigNameArr) + 1)
          For Each vConfigName In vConfigNameArr
              Debug.Print "  " & vConfigName
              vCustInfoNameArr = swModel.GetCustomInfoNames2(vConfigName)
              If Not IsEmpty(vCustInfoNameArr) Then
                  For Each vCustInfoName In vCustInfoNameArr
                      Debug.Print "    " & vCustInfoName
                      Debug.Print "      Type     = " & swModel.GetCustomInfoType3(vConfigName, vCustInfoName)
                      Debug.Print "      Value    = " & swModel.GetCustomInfoValue(vConfigName, vCustInfoName)
                      Debug.Print "      Text     = " & swModel.CustomInfo2(vConfigName, vCustInfoName)
                  Next
              Debug.Print "  ---------------------------"
          Next
