I know that a lot of people avoid using gasket in their routing because of the possible issues. Unfortunately, i work in such environment that i need to use gaskets on a regular basis (we work on a lot of complex piping system which will require me to use gasket for proper spacing, fabrication details as well just counting them).
My problem is simple in nature. Let's say i have a flange and i take gasket from my library to drag and drop it onto the flange, matting reference is working properly. Now when i want to insert mating flange to the other side of the gasket 2 things happen:
1) mating reference picks up the same side of the gasket, which was used to mate to first flange, or
2) flange picks up the mating reference from the first flange.
I was careful when i was developing mating reference in gaskets and flanges and have no idea how to bypass this.
Now i know that some will think of inserting the whole assembly to the route (flange+gasket+flange), but in some cases i cannot do that (start of the route fr example).
I have attached model of the gasket and one of the flanges.
Any help is appreciated
I see what you are trying to do with the mate references here but may I suggest simplifying things. I don't have a lot of experience with using multiple mate references on a part but when I have tried it hasn't worked. See if these simplified versions will do what you want. It will not lock the angle but should snap to whatever outer face you want.
