Hello.
I am trying to translate a sketch from a vertical plane to an angled plane.
So I copy it and paste it onto a new plane that I angled to a precise angle I wanted...
I tried to fully define my sketch so I could move it to place and it won't change.
When I defeined with dimensions, it turned black, however I was not sure what it was hooked to as there were no anchors.
Why when I fully define a sketch with dimensions, it turns black? I deleted the origin and tried to line this sketch up with previous geometry...
No luck.
I cannot move it without distorting it. I run into this problem a lot, with sketches of various complexity.
What shall I do?
Whats the official way to do this?
Thank you.
--VT
Without looking at the file it might be bit difficult to tell the issue. But in case you've a complex sketch you want to copy, you can make a block out of it and copy/move that block easily.
