I'm making a simple animation in composer from existing views I've created. The views I have are set up with callouts and BOM tables. They appear correct in the Views Mode, but when scrolling throught the timeline in Animation Mode the Callouts are empty. I noticed the BOM tables do not show in the animation either. I did a simple drag and drop from view pallette to the timeline, when setting up the animation. Am I missing something in order to make the balloons keep their BOM ID's in the animation mode? Thanks.
Hi Silas,
This sounds like a limitation of how views can have different BOMs and BOM IDs from view to view, but in animation mode, you can only have 1 BOM and 1 set of BOM IDs.
If the BOM IDs are changing from view to view and you are dragging/dropping those views onto your timeline, this will cause issues and the callouts will show up blank. This can be solved by assigning BOM IDs and then setting those as neutral properties for all of your actors. However, this forces all actors to share 1 set of BOM IDs.
These details were defined in SPR#661878
