So I'm not well-versed on using surfaces so I will discuss this to the best of my ability.
I am trying form the surface of an object (oblong/domed) of which we picked points from using a CNC machine.
This was done using a grid pattern so each point is exactly on a 1 inch grid in x and y, and in z on the various height it would range.
We however, don't have just points, since this was done using a ball cutter. So the points were then used to create a series of "balls" in the CAD file, with each "ball" touching the tangent edge of the part we measured, representing the ball cutter on the CNC machine.
I was going to create sketches on planes which intersect the balls, but since the balls would be touching the tangent edge of the surface, it would be near impossible to choose the correct location of the plane for that tangent.
My question now becomes, is it possible to create a surface in which touches all of these "ball" solid bodies at tangent points to create our domed surface?
Thank you for your time in advance,
~Anthony
This can be a start. It's not perfect, but is close being the balls protrude through the surface a bit and the curvature or tangency isn't great but I'm not putting much time into it as it's not my project or job on a Saturday afternoon.
