0 Replies Latest reply on Nov 15, 2013 8:22 AM by Jiten Dutia
    flat pattern to dwg with custom properties
    Jiten Dutia
      Hello Guys,
      I would like to get some assistance in getting my macro programmed. I have the following macro to create flatpattern view of a sheetmetal part and export it to a dwg without any bend lines. I wanted to add few custom properties (ex. sheetmetal part has a property called Quantity, thickness etc.) to this dwg? is it possible, if so how? Any help would be greatly appriciated.
      Also i have the following code working as a pdm task. I would like to include these custom properties option into this task as well to make it automated.
      Option Explicit
          Dim swModel                 As SldWorks.ModelDoc2
          Dim vConfNameArr            As Variant
          Dim vConfName               As Variant
          Dim bShowConfig             As Boolean
          Dim bRebuild                As Boolean
          Dim bRet                    As Boolean
          Dim swDocSpecification      As SldWorks.DocumentSpecification
          Set swDocSpecification = swApp.GetOpenDocSpec("<Filepath>")
          Set swModel = swApp.OpenDoc7(swDocSpecification)
          Set swModel = swApp.ActiveDoc
      'Is it a part document?
      Dim modelType As Long
      modelType = swModel.GetType
      If modelType <> SwConst.swDocPART Then
          'swApp.SendMsgToUser2 "A sheet metal part must be open.", swMbWarning, swMbOk
          Exit Sub
      vConfNameArr = swModel.GetConfigurationNames
      For Each vConfName In vConfNameArr
          If (Strings.Right(vConfName, 7)) = "PATTERN" Then
          bShowConfig = swModel.ShowConfiguration2(vConfName)
          bRebuild = swModel.ForceRebuild3(False)
          Dim FilePath As String
          Dim PathSize As Long
          Dim PathNoExtension As String
          Dim NewFilePath As String
          FilePath = swModel.GetPathName
          PathSize = Strings.Len(FilePath)
          PathNoExtension = Strings.Left("<Filepath>", PathSize - 6)
          NewFilePath = PathNoExtension & "DWG"
          'Export Flat Pattern
          bRet = swModel.ExportFlatPatternView(NewFilePath, swExportFlatPatternOption_RemoveBends)
      Next vConfName
      'Close the document
      swApp.CloseDoc (swModel.GetTitle)
