3 Replies Latest reply on Nov 14, 2013 11:31 AM by Oleg Bezyaev
    IntersectCurve
    Oleg Bezyaev
      Is there a way to determine at what point the line intersects the curve of any type(line, arc, circle, spline)?
      Maybe do it with some tessellation?
        • Re: IntersectCurve
          Oleg Bezyaev
          I invented like this:
          ICurve anyCurve = myEdje.GetCurve();
          ICurve lineCurve = CreateLine(rootSwApp.IGetModeler(), new double[]
          { myCenterPlane.ArrayData[0], myCenterPlane.ArrayData[1], myCenterPlane.ArrayData[2] },
             new double[] { vectorX.ArrayData[0] + myCenterPlane.ArrayData[0],
                            vectorX.ArrayData[1] + myCenterPlane.ArrayData[1],
                                                    vectorX.ArrayData[2] + myCenterPlane.ArrayData[2] });
          double[] lineCurvePoints = lineCurve.Evaluate2(0, 2);
          double[] anyCurvePoints = anyCurve.Evaluate2(0, 2);
          double[] firstStart = new double[]{lineCurvePoints[0],lineCurvePoints[1],lineCurvePoints[2]};
          double[] firstEnd = new double[] { lineCurvePoints[3], lineCurvePoints[4], lineCurvePoints[5] };
          double[] secondStart = new double[] { anyCurvePoints[0], anyCurvePoints[1], anyCurvePoints[2] };
          double[] secondEnd = new double[] { anyCurvePoints[3], anyCurvePoints[4], anyCurvePoints[5] };
          double[] res = lineCurve.IntersectCurve
              (anyCurve,
              new double[] { firstStart[0], firstStart[1], firstStart[2] },
              new double[] { firstEnd[0], firstEnd[1], firstEnd[2] },
              new double[] { secondStart[0], secondStart[1], secondStart[1] },
              new double[] { secondEnd[0], secondEnd[1], secondEnd[2] });
          But the approximation turned out terrible.
              Mohammed Elkalakhi
              Use this to get your start and end points,
              It is a VB NET sample !!
              If TypeOf swSegment Is SketchSegment Then
                          Dim swSketchSegment As SketchSegment = CType(swSegment, SketchSegment)
                          swCurve = swSketchSegment.GetCurve
                          Dim swSkPoint1 As SketchPoint = Nothing
                          Dim swSkPoint2 As SketchPoint = Nothing
                          Select Case swSketchSegment.GetType
                              Case swSketchSegments_e.swSketchLINE
                                  Dim swSkLine As SketchLine = swSegment
                                  swSkPoint1 = swSkLine.GetStartPoint2()
                                  swSkPoint2 = swSkLine.GetEndPoint2()
                              Case swSketchSegments_e.swSketchARC
                                  Dim swSkArc As SketchArc = swSegment
                                  swSkPoint1 = swSkArc.GetStartPoint2()
                                  swSkPoint2 = swSkArc.GetEndPoint2()
                              Case swSketchSegments_e.swSketchSPLINE
                                  Dim swSkSpline As SketchSpline = swSegment
                                  Dim swSkPoints As System.Array = swSkSpline.GetPoints2
                                  swSkPoint1 = swSkPoints(0)
                                  swSkPoint2 = swSkPoints(swSkPoints.Length - 1)
                              Case swSketchSegments_e.swSketchELLIPSE
                                  Dim swSkEllipse As SketchEllipse = swSegment
                                  swSkPoint1 = swSkEllipse.GetStartPoint2()
                                  swSkPoint2 = swSkEllipse.GetEndPoint2()
                              Case swSketchSegments_e.swSketchPARABOLA
                                  Dim swParabola As SketchParabola = swSegment
                                  swSkPoint1 = swParabola.GetStartPoint2()
                                  swSkPoint2 = swParabola.GetEndPoint2()
                          End Select
                          dbPoint1 = {swSkPoint1.X, swSkPoint1.Y, swSkPoint1.Z}
                          dbPoint2 = {swSkPoint2.X, swSkPoint2.Y, swSkPoint2.Z}
                      ElseIf TypeOf swSegment Is Edge Then
                          Dim swEdge As Edge = CType(swSegment, Edge)
                          swCurve = swEdge.GetCurve
                          Dim swCurveParamData As CurveParamData = swEdge.GetCurveParams3
                          Dim swVertex1() As Double = swCurveParamData.StartPoint
                          Dim swVertex2() As Double = swCurveParamData.EndPoint
                          dbPoint1 = {swVertex1(0), swVertex1(1), swVertex1(2)}
                          dbPoint2 = {swVertex2(0), swVertex2(1), swVertex2(2)}
