5 Replies Latest reply on Nov 13, 2013 2:44 PM by John Weakley
    VBA save dxf to file directory that does not include selected path
    John Weakley
      I have a problem with this vba I got online, it works but it somehow includes the file path directory inside the saved filename.
      So if a directory is selected called C:\Desktop\123\ then the filename will be saved as "123.filename.dxf"  I don't know how to remove the top folder out of the saved filename.
      Please help.
      John
      Dim swModel As ModelDoc2
      Dim swView As View
      Dim SelMgr As SelectionMgr
      Dim boolstatus As Boolean
      Dim Feature As Object
      Dim blankTemplate As String
      Dim sheetName As String
      Dim templateWidth As Double
      Dim templateHeigh As Double
      ' EDIT TO SUIT YOUR OWN NEEDS
      blankTemplate = "blank a3.slddrt"    ' Location of the template you wish to use for the Profile sheet (Usually a blank one)
      templateWidth = 0.297                ' Width and height of
      templateHeight = 0.21                ' the above template
      sheetName = "DXF"                ' 1:1 Flat pattern sheet name
      Set swModel = swApp.ActiveDoc
      Set SelMgr = swModel.SelectionManager
      swModel.NewSheet3 sheetName, 12, 12, 1, 1, False, blankTemplate, templateWidth, templateHeight, True
      ' Get path of drawing and rename extension to SLDPRT
      ' get array of dependencies from the active document
      Dim dependencies As Variant
      dependencies = swModel.GetDependencies2(True, False, False)
      Dim partfile As String
      partfile = dependencies(1)
      Set swView = swModel.CreateFlatPatternViewFromModelView3(partfile, "", 0.15, 0.1, 0, True, False)
      Dim swAnn As SldWorks.Annotation
      Set swAnn = swView.GetFirstAnnotation2
      Do While Not Nothing Is swAnn
          swAnn.Visible = swAnnotationHidden
          Set swAnn = swAnn.GetNext2
      Loop
      swModel.ViewZoomtofit2
      'Save As DXF
      If MsgBox("Save as DXF?", vbYesNo) = vbYes Then
           'Save
          Dim savePath As String
          Dim bRet As Boolean
          Dim newfilepath As String
          Dim sfilename As String
          Dim strings As Variant
          Dim strrevname As String
          sfilename = swModel.GetTitle
          strings = Split(sfilename, " - ")
          sfilename = strings(0)
          strrevname = swModel.CustomInfo2("", "Revision")
          savePath = SelectFolder()
              If Len(savePath) Then
                  'MsgBox savePath
              Else
                  MsgBox "Cancel was pressed"
          newfilepath = savePath & sfilename & strrevname & ".DXF"
          bRet = swModel.SaveAs(newfilepath)
      Function SelectFolder() As String
          Dim objShell As New Shell32.Shell
          Dim objFolder As Shell32.Folder
          Set objShell = CreateObject("Shell.Application")
      'If you use 16384 instead of 1 on the next line,
      'files are also displayed
          Set objFolder = objShell.BrowseForFolder _
                                  (0, "Please select a folder", 0, 0)
          If Not objFolder Is Nothing Then
              SelectFolder = objFolder.Items.Item.Path
      End Function
