Hi All,
I am trying to build a window framing template with same extrusions on top and both sides.of the frame, but it seems that if I have two variables refering to the same length of extrusion, only one will come to effect which actually changes the length of original file to make it match the desired length.
Is there any method that I could set up parts with lenghts under different equation in one assembly?
For example, Post A(1) L=2000, and Post A(2) L = 1800 by equations?(not configuration)
Cheers.
Keith
I can creat another file named in extra words like "Jamb of xxxx" but it just brings in massive of works when we try to modify it. Or can I create an dummy file (still links back to the master part fiel)just to allow the assembly to 'store' the global variable in it so it won't conflict when I have multipal variables?
