Automatic route on drop of connector does not work.
Question asked by Ryan Rubado on Nov 12, 2013
Latest reply on Nov 12, 2013 by Ryan Rubado
Does anyone else have this issue? Is there a fix/workaround?
The problem is when I insert a connector it will not prompt me to start a new route even though the check box is checked. It will work if I insert a connector into a new assembly, but not if I insert it into an existing assembly.
I have found that if I insert the connector nothing happens, but if I copy it within the assembly SW brings up the route diologue box. It's a workaround, but It's also an extra step.
Is there a way to manually create a route assembly? I would like to insert new route assembly, then drag my connectors into it, then route so I have no external references. I would just put the connectors into the top level assembly and start a route, then drag the connectors into the routing sub-assembly, but then there are external references within the sketch, that even when deleted, do not go away. I do not like external references because SW cannot handle them as they claim it will.
Any help would be greatly appreciated. Thanks.
