Hi i have a problem with my weldment cut list, it some cells (picture 2) it dosent show the same weight as in cut-list properties (picture 1)
But if i remove the text expression and write the weigt manually in cut-list properties it showa correct weigts on drawing. Anyone who knows what
the problem is. Is the expressions correct?
I have just start working with Solid is an old NX user.
For info cut list pos no will be draw pos no
1 - 11
2 - 6
3 - 14
4 - 2
5 - 5
6 - 9
7 - 8
8 - 4
9 - 3
10 - 17
11 - 18
12 - 13
13 - 12
14 - 10
15 - 16
17 - 1
18 - 7
Welcome to SolidWorks forums Jonny.
Not sure what can be the reason. Try this: Right click on the cut list while in the part mode and select "Update". Now verify if the value updates. If not then can you please attach the part and the drawing so that one can open the files and check them.
Please use "advanced editor" in case you want to attach any files.Click on reply and then click "use advanced editor".
You might also find this post helpful for your future reference.
