Hello all,
I'm trying to animate a part in a sub-asembly. In the subassembly properties I have "Solve as flexible" checked, and the component is mated such that it will move the way I want when I have the sub-assembly open as it's own assembly. There are no mates between the sub assembly component and top level assembly components outside of it.
However, I still can't drag the part when I'm in the top-level assembly. Can anyone offer any help?
I've had problems with this and had to go from the bottom up going through each level of assembly checking for the level where it stops being flexible. Is it solved as flexible in the top level assembly and all the ones below it?
