server-log: "Initializing global settings" all the time
Question asked by Robert Hametner on Nov 11, 2013
Hi there!
Is it normal that Workgroup PDM is constantly initializing the global settings?
It initializes that often, the pdm logfile grows about 6 Mb each year...
Actually this issue isn't new, we have it since 2006.
But at the moment we are having some troubles because of very slow checking in to the vault.
For me personally it seems that the difference in speed occured with the update from 2011 to 2013, but I am checking all possibilites.
10/16/2013 19:22:53                ******************************************************************************************************************
10/16/2013 19:22:53       SolidWorks Workgroup PDM 2013 SP4.0 Server Log Started. (VERSION: 2  BUILD: 2212232871).
10/16/2013 19:22:53       Logging message types: (65585) - Normal, ErrorX, ErrorA, Notify
10/16/2013 19:22:53       Request ports open but unable to handle most requests until server fully running.
10/16/2013 19:22:53       Registry value 'Force Update' set to ''.
10/16/2013 19:22:53       Registry value 'Validate Vault' set to 'TRUE'.
10/16/2013 19:22:53       Registry value 'Validate Vault Next Startup' set to 'FALSE'.
10/16/2013 19:22:53       Registry value 'Validate Vault Every Startup' set to 'TRUE'.
10/16/2013 19:22:53       Registry value 'Repair Vault' set to ''.
10/16/2013 19:22:53       Vault was last opened by SolidWorks Workgroup PDM 2013 SP4.0 (BUILD: 2212232871).
10/16/2013 19:22:53       Validating vault.
10/16/2013 19:22:53       Start: Validating vault folder and file structure.
10/16/2013 19:21:51       End: Validating vault folder and file structure.
10/16/2013 19:21:51       Successfully validated the vault folder and file structure.
10/16/2013 19:22:13       Start: Initializing object manager.
10/16/2013 19:22:13       Start: Initializing projects.
10/16/2013 19:22:21       End: Initializing projects.
10/16/2013 19:22:21       Start: Initializing access manager.
10/16/2013 19:22:26       End: Initializing access manager.
10/16/2013 19:22:26       Start: Initializing revision manager.
10/16/2013 19:22:26       End: Initializing revision manager.
10/16/2013 19:22:26       Start: Rebuilding project tree info.
10/16/2013 19:22:26       Registry value 'Fix Duplicates' set to ''.
10/16/2013 19:22:26       Rebuilding tree info for project: 000002
10/16/2013 19:22:26       Statistics for project 000002: 7 Unique Files and 7 Revisions
10/16/2013 20:06:13       Tree rebuilt for project: 101100
10/16/2013 20:06:13       Rebuilding tree for project: 100000
10/16/2013 20:06:13       Tree rebuilt for project: 100000
10/16/2013 20:06:13       End: Rebuilding tree.
10/16/2013 20:06:13       End: Finished rebuilding project trees.
10/16/2013 20:06:14       End: Initializing object manager.
10/16/2013 20:06:14       Start: Initializing memory tree cache.
10/16/2013 20:06:25       End: Initializing memory tree cache.
10/16/2013 20:06:31       Server is running.
10/16/2013 20:06:31       Request Port listening for connections on PORT: 40000. WORKER THREADS: 10
10/17/2013 09:04:58       Start: Initializing global settings.
10/17/2013 09:04:58       End: Initializing global settings.
10/17/2013 09:06:31       Start: Initializing global settings.
10/17/2013 09:06:31       End: Initializing global settings.
10/17/2013 09:33:20       Start: Initializing global settings.
10/17/2013 09:33:20       End: Initializing global settings.
10/17/2013 09:36:31       Start: Initializing global settings.
10/17/2013 09:36:31       End: Initializing global settings.
10/17/2013 09:50:24       Start: Initializing global settings.
10/17/2013 09:50:24       End: Initializing global settings.
10/17/2013 09:51:31       Start: Initializing global settings.
10/17/2013 09:51:31       End: Initializing global settings.
10/17/2013 09:52:17       Start: Initializing global settings.
10/17/2013 09:52:17       End: Initializing global settings.
10/17/2013 09:56:31       Start: Initializing global settings.
10/17/2013 09:56:31       End: Initializing global settings.
10/17/2013 10:20:45       Start: Initializing global settings.
10/17/2013 10:20:45       End: Initializing global settings.
10/17/2013 10:21:31       Start: Initializing global settings.
10/17/2013 10:21:31       End: Initializing global settings.
10/17/2013 12:17:08       Start: Initializing global settings.
10/17/2013 12:17:08       End: Initializing global settings.
10/17/2013 12:17:53       pdmw_CloseServerSocket Error - socket shutdown returned -1
10/17/2013 12:20:33       pdmw_CloseServerSocket Error - socket shutdown returned -1
10/17/2013 12:21:31       Start: Initializing global settings.
10/17/2013 12:21:31       End: Initializing global settings.
10/17/2013 12:21:33       Start: Initializing global settings.
10/17/2013 12:21:33       End: Initializing global settings.
10/17/2013 12:26:31       Start: Initializing global settings.
10/17/2013 12:26:31       End: Initializing global settings.
10/17/2013 13:22:27       Start: Initializing global settings.
10/17/2013 13:22:27       End: Initializing global settings.
10/17/2013 13:22:28       pdmw_CloseServerSocket Error - socket shutdown returned -1
10/17/2013 13:22:29       pdmw_CloseServerSocket Error - socket shutdown returned -1
10/17/2013 13:26:31       Start: Initializing global settings.
10/17/2013 13:26:31       End: Initializing global settings.
10/17/2013 13:26:38       Start: Initializing global settings.
10/17/2013 13:26:38       End: Initializing global settings.
10/17/2013 13:31:32       Start: Initializing global settings.
10/17/2013 13:31:32       End: Initializing global settings.
10/17/2013 14:32:53       Start: Initializing global settings.
10/17/2013 14:32:53       End: Initializing global settings.
10/17/2013 14:36:31       Start: Initializing global settings.
10/17/2013 14:36:31       End: Initializing global settings.
10/17/2013 14:47:41       Start: Initializing global settings.
10/17/2013 14:47:41       End: Initializing global settings.
Robert
