I am inserting a decal into an assembly and it seems to work fine while I am working on it. The decal stays put and I have no problems as long as the assembly is checked out from the vault and I am working on it. However, once I check the assembly back in the decal does not appear anymore. I do have the view decals option turned on so I know that is not the problem.
The strange part comes after I check the assembly back in and then try to reopen it. When I click to open the assembly it pops up on my screen and I wait as the whole assembly loads. While it is loading the decal I had placed appears just as it was. However, once the assembly is fully loaded (this takes about 5 seconds) the decal disappears. When I check for the decal in the "View Decals" under Display Manager in the design tree it is no longer there, as if I had never inserted it in the first place.
Obviously there is still some data referring to the decal since it appears during the loading phase but afterwards it is 100% gone. This is most likely a simple fix but I'm stumped. Any help would be appreciated.
Add your decal at the part level not the assembly level.
In options/document properties/model display check the box for storing decal info with the file (just to be safe)
