I am trying to pattern a component in an assembly and skip
different instances between configurations. Does anyone know if
this can this be done?
Also, I am driving a pattern on a part from a pattern in an assembly. The same instances need to be skipped between the part and the assembly. I am currently using equations to drive the spaces and number of instances between the part and the assembly which is working great. Can equations be used to link the instance skipping property between parts and assemblies? Can a design table drive instance skipping in a pattern?
Any help or suggestions is greatly appreciated. Thanks.
