2 Replies Latest reply on Nov 7, 2013 9:24 AM by Tony Szuta
    Remove Material
    Tony Szuta
      Hi everyone. It's been quite a while since I dabbled with any sort of code. I've got a simple task at hand that I hope someone can help me out with.
      All that I am trying to do is remove material that has been assigned to a part. As for assigning material, I've got that working OK. I just need to do the opposite.
      Here is the line of code I am using to apply a material from our library:
           swPart.SetMaterialPropertyName2 swApp.GetActiveConfigurationName(swPart.GetTitle), "**PathRemoved**/CustomMaterialLibrary.sldmat", "304 SS, 7 GA."
      I've skimmed through the API help but can't seem to find what I am after. I have tried swPart.DELETEFRIGGINMATERIAL but for some reason it doesn't seem to work. LOL
      Thanks in advance. Any help is appreciated as usual.
        • Re: Remove Material
          Deepak Gupta
          Try these codes:
              Dim swApp                       As SldWorks.SldWorks
              Dim swModel                     As SldWorks.ModelDoc2
              Dim swPart                      As SldWorks.PartDoc
              Dim sMatDB                      As String
              Set swModel = swApp.ActiveDoc
              Set swPart = swModel
              swPart.SetMaterialPropertyName2 "", "", ""
