4 Replies Latest reply on Nov 14, 2013 3:16 PM by Steve Martens
    How does people make a design with solidworks correctly? (matching with ERP)
    Ozkan Isik
      Hi everybody.
      We produce cnc sheet forming machine. I couldnt understand, how does people make a machine design with solidworks correctly? (matching with ERP)
      solidworks is not enough for manufacturing (weldment (frame)- cosmetic thread (multi body- sub-assembly)- welding (cuttable).
      Inventor and Solidedge are very successful in this regard. you can see by youtube.
      https://www.youtube.com/watch?v=wNIkbWXX1N8
      https://www.youtube.com/watch?v=CkxpMGibujo
      1- solidworks has pressed to design only part environment . how can you make assembly on part environment (weldment)??? this is unacceptable for ERP.
      I cannot make sense of this logic
      2- you can not see cosmetic threads multibody on assembly. (upper assembly)... Solidworks said that they will solve this problem 2014 sp2.
      I think anybody doesnt use this process (part design - assembly for welding - assembly for machining - assembly for final desing)
      3- you can not make welding design. you can not show to weld bead correctly on drawing for welding manufacturing and you can not cut to weld bead.
      ---- I want to know that how does people make a design with solidworks. (matching with ERP)
      Thank you..
      best regards
