Basically I have two plates on top of each other. I want to split the bottom plate into the exposed part and the part that is covered by the top plate.
I need these seperate surfaces for analysis in another program (Ansys).
I am using configuration of the bottom plate because it varies in size and so the location of the top plate changes.
Would it be possible to split the bottom plate at the location where the top plate meets and could this split line update withe the new location
Is this a single part in the assemble. if it is make 2 seperate parts and mate them together.
