I am running a new C2D 6600 with a NVIDIA Quadro FX 550 card
and Solidworks 2004 SP2.1, and am unable to turn on Realview
graphics. I am using the 84.26 drivers, which are the latest
supported ones for 2005 (the SW website doesn't list the supported
2004 drivers).
Things I have tried:
Tools>Option>Performance>Use Software OpenGL is unchecked (always)
Shaders folder is present with presumably all files
Successfully turned on RealView in 2006 installed on the same machine.
Tried Part / Assemblies with textures / materials / colors applied
Edited material >Visual Properties - RealView is greyed out.
Double checked the install to make sure RealView was selected.
Did a repair on the installation.
Any other ideas?
Any other ideas?
Please go here:
http://www.nvidia.com/page/par...ertified_drivers.html
scroll down to SolidWorks and click the 'Certified Drivers' link
We're running nVidia Quadro FX 1400 128MB and using driver 71.84
I just checked and Real View worked, but I had to 'Edit Material' in SW to trigger it, if that makes sense.
We're running SW2006 SP 4.1
Since you're running older SW, you may need an older driver.
And try editing the material to force a change, after you turn on Real View.
Good Luck!!
