hi everybody,
The Shaded Cosmetic threads passing through multiple components in an assembly are not displayed correctly. you can see attechment file
spr 707783
I want to know that how do you work with this bug. solidworks can not show cosmetic thread on assembly correctly . Does anyone use manufacturing method on solidworks design.
thank you
definitely. thank you.
solidworks knows this bug and accepted. solidworks said that this bug will be solve on 2014 sp2. if you have solidworks you can try this app. ı want to know that how to use solidworks users this program with this bug? which method is used? (part design - assembly design (weldment) - machining design - drawing). could I have explained my problem?
thank you
I had the same issue ozkan. The only workaround I see is to make actual threads using sweep cut.
thank you krisha for your reply. but its unacceptable.
If we have cad program for manufacturing it should be make this work. if it can not do this correctly, they must fix the program. I said that solidworks is not enough for manufacturing (weldment (frame)- cosmetic thread - welding (cuttable). Inventor and Solidedge are very successful in this regard. everything is clear.
we produce cnc sheet forming machine. I couldnt understand, how does people make a design with this program correctly? (matching with ERP)
thank you
I am running SW 2014 SP 2.0 and this issue is still present, the cosmetic thread is still showing through different parts in an assembly, very annoying. Also, when you make a hole with hole wizard through all on an axis, the end of the thread is shown incorrectly ( see image)
Please Think a cad program, it cant make a hole with cosmetic thread.
solidworks knows this issue but they cant solve this problem. solidworks was collapsed.
