Brooke Colley
VIEW PALETTE PROBLEM
Discussion created by Brooke Colley on Dec 13, 2006
Latest reply on Jan 9, 2007 by SolidAir
Isn't anyone else irritated with the problem of inserting flat patterns using the view palette?
I submitted this to my VAR the very first day I started using 2007 and a SPR was submitted but it hasn't been adressed in the sp's from what I can see.
If you use the view palette to insert a flat pattern into your drawing it does not use the same naming convention if you were to insert it the normal way. This creates major problems in parts with multiple configurations.
I can't believe no one else has complained on here about it. I have turned off the view palette and am not using it until they get things fixed. Please send an enhancement request if this is bothering you too!!
