2 Replies Latest reply on Nov 4, 2013 7:29 PM by Tom Smith
    Get Folder variables in Convert task script
    Tom Smith
      Hi all,
      I'm having trouble making a EPDM convert task script that grabs a variable from the folder data card where the file resides.  I found this snippet in a KB solution that works for file data card variables, but can't seem to get to the folder variables.  I can get the iEdmFolder7 object, but can't assign the folder to a IEdmEnumeratorVariable5 because I can't load references in a convert script.
      here's the snippet that grabs file card values:
      Private Function GetVariableValue(FilePath, VariableName, Configuration)
          On Error GoTo ErrHand
          Dim File As Object
          'Get the interface of the file (and its parent folder)
          Dim Folder As Object
          Set File = vault.GetFileFromPath(FilePath, Folder)
          'Obtain the variable interface
          Dim pEnumVar As Object
          Set pEnumVar = File.GetEnumeratorVariable
          Dim Value As Variant
          If pEnumVar.GetVarfromDB(VariableName, Configuration, Value) Then
              GetVariableValue = Value
          Else
          GetVariableValue = ""
          Exit Function
      ErrHand:
          Dim ename As String
          Dim edesc As String
          vault.GetErrorString Err.Number, ename, edesc
          Log "GetvariableValue error" & vbCrLf & ename & vbCrLf & errdesc
      End Function
      How do I get to the folder variables?
