Hi there,
I am trying to figure out how to make a partial bend on a flat sheet. What I want to do is attached as a file SW2012SP4.
Using the Sketch bend command the desired result is not achieved because the bend line has to be from side to side of the sheet. What I want is the press brake to bend the sheet to 150deg open angle 3/4 of the sheet and the rest 1/4 of the sheet to be freely relieved to its original flatness.
Of course if it is possible I would also like to be able to get a flat pattern of the result because that partial bend shoult not be the only bend on that sheet.
There are at least two ways to achieve what you want.
Add a slit (before the Sketch Bend) where you need the sketch bend to stop.
-or-
Add a partial Edge Bend (use the Edit Flange Profile), and then add a Tab.
