Hi there,
I created a sheet metal using "Base Flange/Tab", and the bounding box length and width show the correct values. However, these parameters (length and width) didn't change correspondingly after I modified the base flange feature. Even some times it shows zero after I updated the cut list... It really makes me frustrated, as I have to remodel the feature to get the correct bounding box length and width.
Can anyone please let me know the solution?
Tony
This may or may not help you, so just take it for what it is worth. Try unsupressing and then supressing the Flat-Pattern1 feature. I have had problems in the past with this and thought maybe it would help. Good luck.
