4 Replies Latest reply on Nov 1, 2013 8:22 AM by Mohammed Elkalakhi
    Trouble with pinned PropertyManager page
    Mohammed Elkalakhi
      Hello everybody;
      I work on an Add-in for solidworks,
      I want to stay in the menu after validation
      So i added a pin in the interface so that then user can choose whether to execute the function once,
      or if he wishes to remain in the menu to execute it several times.
      But i can't re-display the PropertyManager page after the add-in finishes its work.
      This my code :
      Private swDoc As ModelDoc2
      Private sispmpage As PropertyManagerPage2
      Public Sub AfterClose() Implements IPropertyManagerPage2Handler9.AfterClose
      ' Code to start the work of the add-in
        swDoc.ClearSelection2(True)
      If pinned Then
      sispmpage.Show2(0) ' <=== carshes here
      sispmpage.Pinned = True
      End
      Thank you in advance
        • Re: Trouble with pinned PropertyManager page
          Artem Taturevych
          You do not need to reopen you Property Page if it is pinned. I assumed you are trying to implement the pin manually. You just need to use the swPropertyManagerOptions_PushpinButton parameter as ‘option’ argument for the SldWorks::CreatePropertyManagerPage. In this case SolidWorks will take care of this.
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Mohammed Elkalakhi
              Hello Artem,
              Thank you for your replay,
              I know that by default, if the property manager page is pinned, the dialog is not closed.
              But if it is pinned; IPropertyManagerPage2Handler8::OnClose(swPropertyManagerPageClose_Apply) is called and IPropertyManagerPage2Handler8::AfterClose is not called.
              And i have to call the IPropertyManagerPage2Handler8::AfterClose handler to allows my add-in to do his work.
              So to call IPropertyManagerPage2Handler8::AfterClose  i used the Err.Raise method with a value of 0 in the implementation of
              To avoid aggravating the user, who expected the PropertyManager page  to remain pinned, i tryed to re-display and re-pin the PropertyManager page after the add-in finishes its work, but this is not accomplished.
                  Artem Taturevych
                  Hello Mohammed,
                  I would suggest you the following scenario to manage this:
                  1) Create a page which includes these two options:
                  swPropertyManagerOptions_PushpinButton - to show the pin button
                  swPropertyManagerOptions_LockedPage - to allow rebuild operations when PMP is active
                  2) Do work you need from within the OnClose notification. You may identify the state using the 'reason' parameter of OnCLose:
                  swPropertyManagerPageClose_Okay - green tick is clicked and PMP is not pinned
                  swPropertyManagerPageClose_Cancel - red cross is ticked
                  swPropertyManagerPageClose_Apply - green tick is clicked and PMP is pinned
                  Please note because you are using the swPropertyManagerOptions_LockedPage it is safe to do all your work from within the OnClose event. AfterClose is no longer required.
                  Hope it helps.
                  Regards,
