2 Replies Latest reply on Nov 27, 2013 12:40 AM by Mahadev Dharme
    Dimension text is not correctly located for perpendicular distance relation
    Mahadev Dharme
      I am getting an issue for dimension text for perpendicular distance relation added using API IModelDoc2::IAddDimension2()
      The issue particularly occurs if there are multiple distance relations (not for same but different entities) applied and only if, out of them a perpendicular distance relation is applied first using API.
      Following is the work flow.
      1. Created three sketch lines(Line1, Line2, Line3) using API ISketchManager::CreateLine()
      2. Added perpendicular distance relation between Point 1 of Line 2 and Line1 using API IModelDoc2::IAddDimension2() with dimension location computed approrpiately
      3. Added horizontal distance relation between end points of Line 3 using API IModelDoc2::IAddHorizontalDimension2() with dimension location computed approrpiately
      The result for above work flow is as shown in snaps WrongResult.jpg and WrongResult_ZoomOut.jpg. The dimension text is not located at the position specified using API IAddDimension2()
      Surprisingly, if the steps 2 and 3 are interchanged (Horizontal relation is added first), then the result is correct as shown in CorrectResult.jpg
      Can anybody tell me why this issue is occurring?
