6 Replies Latest reply on Oct 30, 2013 12:46 PM by Don Cheke
    PDF Does Not Open Automatically After Creation
    Don Cheke
      Hi All,
      I have been using the macro below to create PDF and DXF copies of drawings since SW2011 and sometime during SW2013 it stopped having the PDF open automatically after creation. Now with SW 2014 is still does not open automatically. Can anyone see any setting in the macro that would need adjusting or can you offer a suggested fix. I do have my PDF filter options set to open automatically after creation when I save a PDF through the save as functions.
      The script as seen in the editor:
      Option Explicit
          Dim swApp                   As SldWorks.SldWorks
          Dim swModel                 As SldWorks.ModelDoc2
          Dim sPathName               As String
          Dim nErrors                 As Long
          Dim nWarnings               As Long
          Dim nRetval                 As Long
          Dim bShowMap                As Boolean
          Dim swModelDocExt           As SldWorks.ModelDocExtension
          Dim swExportData            As SldWorks.ExportPdfData
          Dim filename                As String
          Dim boolstatus              As Boolean
          Dim lErrors                 As Long
          Dim lWarnings               As Long
          Dim bRet                    As Boolean
          Set swModel = swApp.ActiveDoc
          ' Strip off SolidWorks drawing file extension (.SLDDRW)
          ' and add DXF file extension (.DXF)
          sPathName = swModel.GetPathName
          sPathName = Left(sPathName, Len(sPathName) - 6)
          sPathName = sPathName + "DXF"
          ' Show current settings
          ' Turn off showing of map
          bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
          Set swModelDocExt = swModel.Extension
          Set swExportData = swApp.GetExportFileData(swExportPDFData)
          filename = swModel.GetPathName
          filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
          boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
          boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
          If boolstatus Then
              MsgBox "Save as PDF DXF successful" & vbNewLine & filename
          Else
              MsgBox "Save as PDF failed, Error code:" & lErrors '
          swApp.SetUserPreferenceToggle swDXFDontShowMap, False
          bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
          If bRet = False Then
              nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
          ' Restore old setting
          swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
