In a flow project where the model has been built so Z is up, how can I reorient the cut plots generated by batch results so that they are not upside-down? I see options for Resize and Orientation, but there is no option to flip the view horizontally or vertically (like there is in the Solver monitor).
i found that there were some limitations with batch results. you may have to flip the model if you're not seeing the control. pretty much everything in solidworks and flow is what you see is what you get. if you can't see it, it probably doesn't exist. also what is working against you probably is that batch results processing is pretty underused so there haven't been a lot of improvements in it. if i get a min, i'll see if i can see a control.
what version/sp are you using?
