Hi, I am facing a problem in soild works top down design.
I am unable to edit the dimension once external equation for that dimensions is deleted.
Hear the detailed explanation...
1. I created a assembly which contains virtual parts.
2. I defined some equation in the assembly file(GLOBAL) and linked this equtions to the part file dimensions via parametric modeling.
3. Now i want to repace these dimensions with design tables.
4. To do so I deleted all the equations.
5. While remaning the part dimensions(extrude height) I am unable to edit it and it gives a message saying "dimension is read only".
Please suggest me how can i modifiy or edit my dimension with out read only error.
Even I can not modifiy the value too.
Thanks and Regards,
Babu Rao K
Dear Sir,
In assembly level, Uncheck open referenced document with read only acess
Regards,
Manikandan
EGS India
