3 Replies Latest reply on Oct 29, 2013 7:52 AM by Deepak Gupta
    Check if a custom properties is there and end macro if empty
    Steven Smith
      Hi folks,
      I’m looking for a line of code that will check to see if a specific custom property is there and if it’s not end the macro process.
      I already have the macro I want set up, but just need this last line (it's actually going to be the first line) that will check to see if the field exists, if not then the macro doesnt need to run.
        • Re: Check if a custom properties is there and end macro if empty
          Deepak Gupta
          Try this:
          Option Explicit
              Dim swApp               As SldWorks.SldWorks
              Dim swModel             As SldWorks.ModelDoc2
              Set swModel = swApp.ActiveDoc
              If swModel.CustomInfo("Description") = "" Then
              MsgBox "Property Doesn't Exists OR No Value is Assigned"
          This will check if there is property or not. And if there is property but no value has been assigned then also will pop up a message. In case there is space in the value, then macro will no show any message.
              Steven Smith
              Sorry Deepak, I had ment to ask if the "Property Name" Existed not the "Value/Expression".
              Sorry for the confusion.
                  Deepak Gupta
                  Ok, sorry for misunderstanding. Try this:
                      Dim vCustInfoNameArr                As Variant
                      Dim vCustInfoName                   As Variant
                         vCustInfoNameArr = swModel.GetCustomInfoNames2("")
                         For Each vCustInfoName In vCustInfoNameArr
                          If vCustInfoName <> "Description" Then        ' Change property name here
                          Debug.Print  "Description property doesn't exists"
                          Next
