2 Replies Latest reply on Oct 28, 2013 7:41 PM by Brad Overstreet
    Get drawing path and filename while traversing component tree
    Brad Overstreet
      I have a macro that runs in an assembly which traverses the component tree recursively to collect and extract some information.  One piece of data that I am missing is the full path and filename for the drawing or sub-assembly.  I did not see a method in ModelDoc2 that would provide that information.  What is the process to get this data?
      I am using SolidWorks 2013 and my macro is written in c#.
        • Re: Get drawing path and filename while traversing component tree
          Josh Brady
          Are you talking about the file path of the drawing (.slddrw) or the model (.sldprt/.sldasm)?  If you are looking for the drawing, there is none.  The drawing references the model.  The model does not reference the drawing.  No part knows what assemblies use it, and no part/assembly knows what drawings reference it.  You can use the Document Manager API to run a "Where Used" search to find documents that reference a given part/assembly file.
          If you just want the path of the referenced part/assy component, just use .GetPathName
