2 Replies Latest reply on Oct 29, 2013 8:56 AM by Brian Long
    Macro help, macro pasted in text
    Brian Long
      I have this macro that was created by Filipe Venceslau for adding a custom property called "open area", running an equation and placing the calculated value in the new custom property. I would like to change this so that it is a configuration specific custom property using the current configuration. I have been looking for the correct way to do this, although I don't have a clue on API and need help.
      ' Written by Filipe Venceslau on 5/15/2012
      On Error GoTo msgError
          'Get solidworks object instance
          'Get modeldoc2 object instance from active doc
          Dim Part As SldWorks.ModelDoc2
          Set Part = swApp.ActiveDoc
          'Get custom property manager (used to manipulate custom properties)
          Dim cpMgr As SldWorks.CustomPropertyManager
          Set cpMgr = Part.Extension.CustomPropertyManager("")
          'Get current config custom property
          Dim swConfig As SldWorks.Configuration
          Set swConfig = swConfigMgr.ActiveConfiguration
          'Declare Variables for OpenArea calculation
          Dim dbScaleFactor As Double
          Dim dbBegFaceArea As Double
          Dim dbFaceArea As Double
          Dim dbOpenArea As Double
          'Define default Titles
          Dim DefaultTitles(5) As String
          DefaultTitles(0) = "1.250 INSERT"
          DefaultTitles(1) = "BLANK254"
          DefaultTitles(2) = "BLANK481"
          DefaultTitles(3) = "BLANK368"
          DefaultTitles(4) = "BLANK366"
          DefaultTitles(5) = "BLANK8060"
          'Define default Values
          Dim DefaultValues(5) As Double
          DefaultValues(0) = 0.73441718
          DefaultValues(1) = 0.4048916
          DefaultValues(2) = 22.77654674
          DefaultValues(3) = 16.89538712
          DefaultValues(4) = 30.51542336
          DefaultValues(5) = 3.14232926
          'Build message and get user input
          Dim strMsg As String
          strMsg = "Please select from the following options, or type in desired value" & vbCrLf & vbCrLf
          For i = 0 To UBound(DefaultTitles)
              strMsg = strMsg & i + 1 & vbTab & DefaultTitles(i) & vbTab & DefaultValues(i) & vbCrLf
          Next
          Dim dbUserInput As Double
          dbUserInput = InputBox(strMsg, "Beginning Face Area", 1)
          Select Case dbUserInput
              Case 1, 2, 3, 4, 5, 6
                  dbBegFaceArea = DefaultValues(dbUserInput - 1)
              Case Else
                  dbBegFaceArea = dbUserInput
          End Select
          'Assign values and calculate variables
          dbScaleFactor = 1550.003
          dbFaceArea = Part.FeatureByName("MYSURFACE").GetBody.GetFirstFace.GetArea * dbScaleFactor
          dbOpenArea = Round(dbBegFaceArea - dbFaceArea, 6)
          'Delete Custom Prop
          cpMgr.swConfig.Delete ("OpenArea")
          'Add Custom Prop
          Call cpMgr.swConfig.Add2("OpenArea", swCustomInfoType_e.swCustomInfoText, dbOpenArea)
          'Notify user and exit
          MsgBox "Done", vbInformation
          Exit Sub
      msgError:
          'msg error when error occurs
          MsgBox Err.Description, vbCritical
        • Re: Macro help, macro pasted in text
          Artem Taturevych
          Check this revised macro:
              Set cpMgr = Part.Extension.CustomPropertyManager(Part.ConfigurationManager.ActiveConfiguration.Name)
              Next
                  Case Else
              End Select
              'Delete Custom Prop
              cpMgr.Delete ("OpenArea")
              'Add Custom Prop
              Call cpMgr.Add2("OpenArea", swCustomInfoType_e.swCustomInfoText, dbOpenArea)
              Exit Sub
          msgError:
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
