Im using sw2003. I created a model with the coordinate system in place, saved it as an .STL file, emailed it to a guy that opened it in 3space. The coordinates have moved in entirely different locations...he said he cant move the location of the coordinate system...any ideas what is going on? Thanks in advance for help.
SW2003?
If you want to use an coordinate system when outputting a file, you need to select it under the options menu when saving. Otherwise, you just get the default coordinate system.
