13 Replies Latest reply on Nov 7, 2013 10:17 AM by Elmar Klammer
    How to use "Update Standard Views" in SW 2013 API?
    Laszlo Szucs
      I would like to use the enclosed macro in SW 2013 but it crashes all the time.
      The "UpdateStandardViews" method doesn't exist in the SW 2013 API but maybe
      there is a way to implement it somehow. I tried to copy the SW 2014 reference files
      (type libraries etc...) into the macro location that helped me in some cases in the past
      but it doesn't work now.
      The task would be to create standard 3 views automatically about different bodies of
      a multibody part based on the user's face selection and put all the views on one sheet.
      I thought it is a good idea to use the "normal to" command to turn each face into the
      right direction one by one and make a "Front" view out of this so the standard 3 views
      creation would be quite simple. (Of course the user has to take care of selecting the
      right surfaces for the front views.)
      Does anybody have an idea how to do this in SW 2013?
      Thanks in advance for your help!
      Laszlo
        • Re: How to use "Update Standard Views" in SW 2013 API?
          Simon Turner
          This was only added in 2014 I' afraid: UpdateStandardViews Method (IModelDocExtension)
          I don't think it is possible to edit the standard views via the API prior to 2014.
          You can create your own views though - that might be a workaround.
              Laszlo Szucs
              Yes, this method was only added in 2014 but I need to do
              something similar (in best case the same) in 2013.
              Creating own views sounds a good idea but I don't know
              how to do it on the quickest and easiest way.
              (The problem is not the creation of the own views only but
              putting them on one sheet one by one.)
                  Simon Turner
                  The first thing to do is to get the view you want. I use ModelView::Orientation3 myself, but that does require a bit of work to calculate the MathTransform. Alternatively you could use RunCommand(swCommands_View_Normal_To) assuming that you have selected a flat face or plane to view normal to.
                  Next use ModelDoc2::NameView
                  Finally use CreateDrawViewFromModelView3 to insert that Named View into the 2D drawing.
                      Laszlo Szucs
                      I used swModel.ShowNamedView2 "*Normal To", -1 to get the view I want (Face was selected).
                      The NameView and CreateDrawViewFromModelView3 are very useful so thanks for that but I faced
                      the next problem: I work with multibody parts and some of the bodies are sheet metals and others not.
                      If the selected face belongs to a sheet metal I have to create a flat pattern view only but I can't do
                      that with CreateFlatPatternViewFromModelView3 because all the other bodies are in the view.
                      I suppose there should be two different ways to solve this:
                      1. Select the required sheet metal body and use only this one to create the flat pattern view
                      2. Create a view with all the bodies. Select the required sheet metal body and turn the view
                      to flat pattern view somehow.
                      I tried both but no success... Probably I tried to use wrong functions or methods.
                      Any idea?
                      Thanks.
                          Simon Turner
                          For multi-body views, you have to select the body from the ModelDoc2 representing the part file.
                          From some old code that I wrote a long time ago, you need to select the flat face on the model, marking it as "1".
                          Also select the body itself with mark "4"
                          Then I think that CreateFlatPatternViewFromModelView3 should work (although I used CreateRelativeView in my old code).
                          Here is my old code:
                              Set myEntity = myFace
                              Set selMgr2 = myDoc.SelectionManager 'myDoc is the ModelDoc2 for the 3d part
                              Set selData = selMgr2.CreateSelectData
                              selData.Mark = 1
                              myEntity.Select4 False, selData
                              myDoc.Extension.SelectByID2 myBody.Name, "SOLIDBODY", 0, 0, 0, True, 4, Nothing, 0
                              Set Draw = swApp.ActivateDoc2(Draw.GetTitle, True, errors) 'switch back to the 2D drawing
                              Set myDraw = Draw 'DrawingDoc object
                              Set myView = myDraw.CreateRelativeView(myDoc.GetPathName, x, y, 0, swRelativeViewCreationDirection_e.swRelativeViewCreationDirection_TOP)
                              Laszlo Szucs
                              Your solution works fine, thank you very much! Here is my updated code based on your one:
                              (One face has to be selected in a multibody part.)
                              Dim selMgr As SldWorks.SelectionMgr
                              Dim selFace As SldWorks.Face2
                              Dim selData As SldWorks.SelectData
                              Dim BoolStatus As Boolean
                              Dim selEntity As SldWorks.Entity
                              Dim selBody As SldWorks.Body2
                              Dim swDrawing As SldWorks.DrawingDoc
                              Dim swView As SldWorks.View
                                  Set swModel = swApp.ActiveDoc
                                  Set selMgr = swModel.SelectionManager
                                  Set selFace = selMgr.GetSelectedObject6(1, -1)
                                  Set selBody = selFace.GetBody
                                  Set selData = selMgr.CreateSelectData
                                  Set selEntity = selFace
                                  selData.Mark = 1
                                  BoolStatus = selEntity.Select4(False, selData)
                                  swModel.Extension.SelectByID2 selBody.Name, "SOLIDBODY", 0, 0, 0, True, 4, Nothing, 0
                                  Set swDrawing = swApp.NewDocument(swApp.GetUserPreferenceStringValue(swDefaultTemplateDrawing), 12, 1.188, 0.84)
                                  Set swView = swDrawing.CreateFlatPatternViewFromModelView3(swModel.GetPathName, "", 0, 0, 0, False, False)
                                Elmar Klammer
                                HELLO SIMON,
                                I can't get the create-relative view call to work. The code runs the swView always ends up "empty" and no view is actually created.
                                Can you post the code for you old makro?
                                Elmar
                                    Simon Turner
                                    I did post my old code above. The rest is specific to a customer project, so I cannot upload the full project. Sorry.
                                        Elmar Klammer
                                        wHello Simon
                                        I have modified the code and tried to make it work. The idea is to have the part open and preselect a face of a multibody.
                                        The macro then opens an existing drawing (same name as part and inserts a relative view). When i run the code it switches from the part to the drawing but the swView comes up as "nothing" and no relativeview is created.
                                        Set swView = swDraw.CreateRelativeview(component, 0.1, 0.01, swRelativeViewCreationDirection_e.swRelativeViewCreationDirection_FRONT, swRelativeViewCreationDirection_e.swRelativeViewCreationDirection_RIGHT)
                                        I am not a programmer and would appriciate  any pointers on how to solve this issue. The existing code i have take from this and other posts and tried to make it work.
                                        Here is the main macro:
                                        Dim component, drawingname, name As String
                                           '____
                                        'Set swApp = Application.SldWorks
                                        selData.Mark = 1
                                        swModel.Extension.SelectByID2 selBody.name, "SOLIDBODY", 0, 0, 0, True, 4, Nothing, 0
                                        component = swModel.GetPathName
                                        Call opendrw.main 'opens drawing of part file
                                        Set swDraw = swApp.ActiveDoc
                                        drawingname = swDraw.GetTitle 'Left(component, Len(component) - 7) & ".slddrw"
                                        swApp.ActivateDoc3 drawingname, False, 0, 0
                                        name = component
                                        Here is the Opendrw module:
                                        Option Explicit
                                        Dim swModel As ModelDoc2
                                        Dim DocName As String
                                        Dim DrwName As String
                                        Dim swLoadErrors As Long
                                        Dim swLoadWarnings As Long
                                        DocName = swModel.GetTitle
                                        DrwName = Left$(DocName, Len(DocName) - 7) & ".slddrw"
                                        DrwName = Replace(swModel.GetPathName, DocName, DrwName, 1, , vbTextCompare)
                                        If Dir$(DrwName) <> "" Then
                                        Set swModel = swApp.OpenDoc6(DrwName, swDocDRAWING, swOpenDocOptions_Silent, "", swLoadErrors, swLoadWarnings)
                                        'swApp.ActivateDoc3 swModel.GetTitle, True, 0, 0
                                            Simon Turner
                                            For CreateRelativeView, you actually need 2 faces selected. The first one is the one you will look onto. The second one defines the horizontal direction. I think it needs to be perpendicular to the first one.
                                            Here is a modifed version of your macro:
                                            Option Explicit
                                            Option Compare Text
                                            Dim component As String, drawingname As String
                                                Dim selFace1 As Face2
                                                Dim selFace2 As Face2
                                                Dim selEntity As Entity
                                                Dim selBody As Body2
                                                Dim selData As SelectData
                                                Dim selMgr As SelectionMgr
                                                Set selFace1 = selMgr.GetSelectedObject6(1, -1)
                                                If selMgr.GetSelectedObjectCount2(-1) > 1 Then
                                                    Set selFace2 = selMgr.GetSelectedObject6(2, -1)
                                                Set selBody = selFace1.GetBody
                                                Set selEntity = selFace1
                                                selData.Mark = 1
                                                If Not selFace2 Is Nothing Then
                                                    Set selEntity = selFace2
                                                    selData.Mark = 2
                                                    BoolStatus = selEntity.Select4(True, selData)
                                                BoolStatus = swModel.Extension.SelectByID2(selBody.name, "SOLIDBODY", 0, 0, 0, True, 4, Nothing, 0)
                                                drawingname = Replace(component, ".sldprt", ".slddrw")
                                                Set swDraw = swApp.OpenDoc6(drawingname, swDocDRAWING, swOpenDocOptions_Silent, "", swLoadErrors, swLoadWarnings)
                                                Set swDraw = swApp.ActivateDoc3(drawingname, False, swRebuildOnActivation_e.swDontRebuildActiveDoc, swLoadErrors)
                                                Set swView = swDraw.CreateRelativeView(component, 0.1, 0.01, swRelativeViewCreationDirection_e.swRelativeViewCreationDirection_FRONT, swRelativeViewCreationDirection_e.swRelativeViewCreationDirection_TOP)
