Is it possible to cut surface parts in assembly? Ok, here is what I want to do:
I want this whole assebly cut in half:
Like this:
So it can be easily done with "section view" in actual assembly. But the problem is that I need this to be shown like this in drawing sheet. Is it possible?
Ari, as far as i know you cant, but you could create configuration of each part that requires a trim and apply thoes config in the assembly-Surfaces cant be cut only trimmed.
Cant you apply a section view inside drawing?
hope it helps
